Activity › Forums › Apple Final Cut Pro Legacy › BackGround Noise
  • BackGround Noise
    Posted by Invisibleshadow on July 10, 2006 at 5:35 pm
    Room,
    I am editing a very important interview and its a disaster! The is air con in the room which creats a constant buzz in the background. Any ideas on how to remove it or decrease it? I am told you can issolate certain levels of sound (ghz) in an edit, is this possible? PLEASE HELP!!!
    Thankyou in advance,
    Francis
    Invisibleshadow replied 20 years, 2 months ago 4 Members · 4 Replies
  • Simon Carlson-thies
    July 10, 2006 at 5:55 pm
    Do you have Soundtrack Pro, that may be able to reduce it, or a program that I believe is called sound soap may also do it for you… How much noise are you trying to get rid of… is it bad enough to the point where it makes portions of the audio usless or is it more background then that… You may not be able to get rid of it all, or at all depending on how bad it is…
    Simon Carlson-Thies,
    Digital Light Graphics And Animation
  • David Roth weiss
    July 10, 2006 at 7:08 pm
    Soundtrack Pro actually does a pretty darned good job. Check out the tutorial that comes with your Studio Package, its a great example that will show you how to get rid of BG noise levels easily and effectively.
    DRW
  • Andreas Karoliussen
    July 11, 2006 at 7:35 am
    Sound Track Pro NR is nice – you can altso try enhancing/amplifying the characteristics in the voice with an EQ.
    that will disbuise some of the noise (same principle as in mp3 encoding;-)
    Good Luck!
  • Invisibleshadow
    July 11, 2006 at 8:11 am
    Thanks guys, will give soundtrack a whirl…
    Francis
