Activity Forums Adobe After Effects Background leaking through fields
  • Background leaking through fields
    Posted by S Gregory on May 9, 2006 at 3:57 pm
    compositing in 1080i.
    when rendering feilds I see my background plate through the fields at the edges of foreground objects as they move accross screen.
    especially at points where contrast is high.
    The field order is correct.
    everything is normal technically, but its a visual problem.
    any tricks to minimize this?
    Steve Roberts replied 20 years, 4 months ago 2 Members · 3 Replies
  • Steve Roberts
    May 9, 2006 at 5:00 pm
    When you masked or roto’ed did you do it at 29.97 or 59.94 fps?
    If 29.97, you should have separated fields, then done it at 59.94.
    Was that it?
  • S Gregory
    May 9, 2006 at 5:48 pm
    no roto in this spot
    its leaking through the edge of a key
    Source is 29.97
    I seperated fields
  • Steve Roberts
    May 9, 2006 at 6:57 pm
    Hm. Did you try keying in a 59.94 fps comp, then rendering that to 29.97 with fields?
