Activity Forums Adobe After Effects background layer
  • background layer
    Posted by Yarin Manes on August 20, 2006 at 2:04 pm
    hey,im new here finally found a forum which is active..
    anyway i wonder if you guys can help me i created an composition
    with few layers/background/texts/audio,im stilll new at AE,and i dont know how to change background after some time in the timeline i mean
    i got a background that runs all over my composition while i animated some text’s and 3d and i wanna know how to change the background
    to fade into other background maybee using the transform?
    thanks in advance
    oxes.
    Filip Vandueren replied 20 years, 1 month ago 2 Members · 3 Replies
  • Filip Vandueren
    August 20, 2006 at 9:12 pm
    Just add a new video-, still- or solid-layer on top of what was the background, drag it so it’s in-point is where you want the fade to occur.
    Now set two keyframes for opacity 0-100% and it will fade over your previous background.
    You can ‘trim’ the layer below it so it doesn’t extend after the 100% mark.
    In after effects, every element has it’s own new layer, so you can’t put something else into the background layer and do a crossfade like in a video editor if you’re wondering.
  • Yarin Manes
    August 21, 2006 at 10:05 am
    okie well it worked ,thanks,
    but i want it more smooth..it just switches between the two backgrounds,i can easy in with keyframe assistance but i dunno how good that will do,is there any effect that do a nice cross between the two backgrounds while objects are running on the layers..?
  • Filip Vandueren
    August 21, 2006 at 7:01 pm
    Set a keyframe for opacity = 0 at the start of the new layer, go a second later and set a keyframe for 100%
    Make sure ‘hold keyframes’ aren’t toggled on by accident, and ypu should have a smooth fade-in of the new BG
