Activity Forums VEGAS Pro Background image on text Vegas Pro 12
  • Background image on text Vegas Pro 12
    Posted by David Mccormick on September 1, 2013 at 2:22 pm
    I am currently working on series of videos about butterflies and moths and for the title text, I would like to have the text look like it has butterfly scales, so I have an image I have imported I want to use as the text background instead of the text color, but I am not sure how to do this.
    Anyone know how I can do this?
    David McCormick
    Thayalan Paramasawam replied 13 years ago 4 Members · 4 Replies
  • Brad Leigh
    September 1, 2013 at 3:30 pm
    https://forums.creativecow.net/readpost/24/968623
    Here is your answer from one of the tutorials listed lower down in this fourm.
    B
    i7 2600 3.4 Ghz 8Gig Ram , Win 7 Pro, Vegas Pro 12
  • John Rofrano
    September 1, 2013 at 5:12 pm
    [David McCormick] “I would like to have the text look like it has butterfly scales, so I have an image I have imported I want to use as the text background instead of the text color, but I am not sure how to do this.”
    Make sure that the text color is White. Then:
    1. Place the text on a separate track (because you will be compositing this track and the composite mode will affect everything on the track)
    2. Place the background on a separate the track below the text
    3. Set the composite mode of the text track to Multiply (Mask). The text face should now be the background
    4. Set the child composite mode of the background track to Make Compositing Child.
    The tracks below these two tracks should now be visible with the background as the text face.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • David Mccormick
    September 1, 2013 at 5:42 pm
    Hi Brand and John,
    Thanks for the information. It worked great for what I wanted. Thanks for the video link Brad, helped with compsiting and sources as I knew it was something to do with that I had to change when I was doing this but wasn’t sure what.
    David McCormick
  • Thayalan Paramasawam
    September 2, 2013 at 4:16 am
    Hi Sir (Mr.John Rofrano)
    Nice tutorial…….can i add video effect (flare lens effect).On which track can apply,i try the effect but its not working.
    Thank You
