Activity › Forums › Adobe After Effects › Background colour visible in Alpha Channel on edges.
  • Background colour visible in Alpha Channel on edges.
    Posted by Matthew Ingram on March 15, 2007 at 2:21 pm
    I need to output a clip with an embedded matte for delivery to a tv channel.
    I’m finding as in the past that After Effects rings all mattes with the colour of the Background.
    Normally this isnt too much of a problem however the current clip only has three colours magenta/black/white.
    A magenta blackground will ring the black edge with magenta -and- the black background will ring the magenta with black.
    I’ve tried exporting a luma matte and using it to mask two different coloured solids but after effects defaults to the background colour regardless.
    Anyone have any suggestions?
    Erik Pontius replied 19 years, 6 months ago 3 Members · 3 Replies
  • Steve Roberts
    March 15, 2007 at 2:26 pm
    Did you render (use the render queue) with straight alpha? Most apps prefer that.
  • Matthew Ingram
    March 15, 2007 at 2:35 pm
    as opposed to premultiplied? no. i’ll try that thank you. i suspect that may do the job.
  • Erik Pontius
    March 15, 2007 at 3:46 pm
    Always use straight mattes where you can. Premultiplied mattes will always include a small amount of the background color in the semi-transparent areas.
    Erik
