Activity › Forums › Apple Final Cut Pro › Back Up Libraries
  • Back Up Libraries
    Posted by James Ewart on September 11, 2014 at 7:09 am
    Due to problems with Backups and having to disable it followed by a massive crash and apparent loss of everything now solved through reinstalling FCPX, I have noticed that the manually backed up library which I had copied to another drive would not open.
    I believe this is because I renamed it having moved it (calling it backup).
    Odd or not odd?
    James
    Lawrence Eaton replied 12 years ago 2 Members · 1 Reply
  • Lawrence Eaton
    September 11, 2014 at 1:01 pm
    Do you have read/write permissions? Or maybe if you had to do a complete rebuild you are using a different user name?
    Lawrence
