Activity Forums VEGAS Pro back to the old Vegasquake days…
  • back to the old Vegasquake days…
    Posted by Steven J casey on February 15, 2007 at 11:29 pm
    Just was working on a project that could use Quake but I can’t get it to install in version 7, keep getting the message that Vegas 5 isn’t found on the computer. Am I missing something easy or will it just not run on 7? I’m not looking to spend money on packages like newblue, etc. Just need a quick effect and Quake was always free…
    Thx
    steven
    Edward Troxel replied 19 years, 6 months ago 5 Members · 8 Replies
  • 8 Replies
  • Mike Kujbida
    February 16, 2007 at 12:13 am
    All I can tell you is what Edward (Troxel) said on another Vegas forum and that was:
    It appears to run fine in Vegas 7 – there’s just no installer for Vegas 7. If you have the four base files, you can simply copy them over to the Script Menu folder in Vegas 7.
  • Carson Young
    February 16, 2007 at 12:41 am
    if you dont mind me asking, does anyone have a link for Quake, i havnt been able to Google it.
    Thanx,
    Carson
  • Mike Kujbida
    February 16, 2007 at 3:44 am
    Google Vegas quake or get this script collection. It’s a part of it and there’s a lot of other useful scripts as well.
  • Edward Troxel
    February 16, 2007 at 3:23 pm
    You still need Vegas 5 in order to initially install it. Otherwise you’ll need someone to send you the individual files. For cases like this, I pulled them out into a zip file so I could just copy them where they needed to be.
    Edward Troxel
    JETDV Scripts
  • Carson Young
    February 16, 2007 at 8:19 pm
    oh, too bad, i dont have 5 only 6
  • Allen Zagel
    February 17, 2007 at 12:45 am
    Okay, so what’s Quake? Sorry to seem stupid. I still got V5 in my machine plus V7.
    …and Mike, that link you gave? I don’t trust that site. Too many pop-ups (blocked) as well as 3rd party cookies (also blocked). Maybe spyware also???? Plus I don’t see a list of the scripts they’re offering in the download.
    Allen
    ASX Media Productions
    https://www.asxvideo.com
  • Mike Kujbida
    February 17, 2007 at 1:13 am
    Allen, I use Firefox and a pop-up blocker so I never see them.
    I guarantee you that the site can be trusted. The guy hosting it is a long-time Vegas user.
    As far as scripts, here’s what’s in it:
    Add Effect And Slow Play
    Add effect to all media
    Add markers at interval
    Add markers to events
    Add Regions To Events
    Add2SecondGap
    Adjust volume
    Apply Random Transition
    Apply transitions
    Aspect ratio
    Audio to new take
    Audit for event levels
    Audit for short blank gaps
    Automated_photo_snapshot
    Batch render
    Batch render gui
    Batch Render GUI (JHM)
    Batch Render Gui JHM
    Blink
    ChangeAlphaChannel
    ChangeMediaPoolAspectRatio
    Chop off front
    CopyVelEnv(e)
    Create tracks
    CurveTypesConcave
    CurveTypesConvex
    CurveTypesLinear
    CurveTypesSmooth
    Delete Empty Space Between Events
    Delete from cursor to event start
    Delete n frames from event
    Delete next frames on all tracks
    Directory converter
    Drum bus and track
    DVDA chapter from Vegas marker
    Event curve types (4)
    Expand events
    Export images for range
    Fade event in out
    Fade in out cursor
    Film look
    Highlight selected fX Events
    Improved Render Gui
    Loop to normalize
    Markers at Media Change Points
    Markers To Regions
    Match aspect
    Move cursor 60 sec left
    Multi Cam Dissolve
    Multi fade
    MulticamWithTakes 1.54
    Normalize all
    One frame from each event
    Opacity level
    Photo_Snapshot
    Play Sound
    Put In First Track End
    Quick Envelope
    Quick pan
    Quick Pan 1.0
    QuickEnvelope2.0[1]
    RC1_filmlook
    Reconstruct Audio events
    Recreate Audio events
    Reduce Interlace Flicker
    Regions from event names
    RegionsToChapters
    Remote Control
    Remove all effects
    Remove Not Active Takes
    Render DVD
    Render image sequence
    Render on markers
    Render queue
    RenderSegs2
    Reverse event
    Select all
    Select all events in single track
    Select all events in tracks
    SelectEventsFromCursor
    Selection area around selected event
    SelectionToMultitakeClips 1.32
    Show number of tracks
    Snapshot to clipboard
    Snapshot to file
    Split Events
    TapTempo
    Test pattern
    Test timeline redraw
    Thumbnail
    Thumbnail at markers
    Time Lapse (1 Frame per Event)
    Tracksetup
    Transitions
    TRIMMODULE 1.12
    VegasQuakeInstall
    Visual Key framer
    wil_maestrochp
  • Edward Troxel
    February 17, 2007 at 2:53 am
    Vegas Quake is a script that will add a bunch of Pan/Crop keyframes to make the selected clip jump around. Today, I prefer to use the effects made by newbluefx for this instead. They’re much easier to control and test.
    Edward Troxel
    JETDV Scripts
