Activity Forums Adobe After Effects Back of a picture in 3d to show another picture
  • Back of a picture in 3d to show another picture
    Posted by Paul Bibby on June 24, 2010 at 12:35 pm
    I’m doing a show reel for a Ad agency and I’m trying to make pictures
    dance like lord of the dance one problem I’m having is that when they flip on the y axis I want the back side of the picture to show another picture is there a easy way to do this. I hope everyone understands this.
    Paul Bibby replied 16 years, 2 months ago 2 Members · 2 Replies
  • Kevin Camp
    June 24, 2010 at 12:59 pm
    a fairly easy way would be to apply the blend effect to the ‘front’ image. use the ‘blend with layer’ property to select the ‘back’ image (that image needs to be in the comp, but does not need to be active — click the ‘eyeball’ icon to hide it; nor does it need any animation).
    now you could animate the ‘blend’ property with hold keyframes to change between front and back images as needed (toggle between 100 and 0), or you could add an expression to the property (select the property in the timeline, then choose animation>add expression) and paste this expression into the expression field:
    if (toCompVec([0, 0, 1])[2] > 0 ) value else 0
    if you want to know more about this expression, i copied it from dan ebbert’s site here:
    https://motionscript.com/design-guide/invisible-facing-away.html
    he had written the expression to go into the opacity properties of two layers, but the blend effect makes it only necessary for the ‘blend’ property, plus the ‘back’ layer won’t need to be animated or parented and flipped.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Paul Bibby
    June 24, 2010 at 1:18 pm
    Thanks that work wonderfully !!!!
