Activity › Forums › Maxon Cinema 4D › b3d files net render
  • b3d files net render
    Posted by Gon Perdigao on November 3, 2011 at 7:08 pm
    hi there, i’m new at net render.
    I render some scenes and chose png files to ouutput, but in the end i end up with b3d files, what i’m dong wrong?
    And how can i import this files into after effects cs5.5?
    Thanks a lot
    Adam Trachtenberg replied 14 years, 10 months ago 2 Members · 3 Replies
  • Adam Trachtenberg
    November 3, 2011 at 9:17 pm
    .b3d is the internal format that Cinema uses. Something must have gone wrong that you wound up with that instead of .png (obviously!). I think you can load them into the picture viewer and then save out in another format.
  • Gon Perdigao
    November 3, 2011 at 9:55 pm
    thanks Adam for the quick reply and help!
    I’ve try to load them to the picture viewer but is all black, or that is normal and when i save to into another format the render will be normal?
    Is there another way to convert it into another format?
    Thanks a lot
  • Adam Trachtenberg
    November 3, 2011 at 11:07 pm
    No, you should be able to see the image in the PV. Not sure what to tell you.
