Activity Forums Maxon Cinema 4D b-splines and curve influence
  • b-splines and curve influence
    Posted by Keith Goldstein on November 13, 2014 at 7:25 pm
    When creating a b-spline, I want to alter the curve that is created, making the curve between two points more acute. Is there a way to do this easily using the points I’ve already created? Adding points closer to the center point of the curve seems to come close to what I want to do, but is there an easier way? Or do I need to use a bezier spline to have that kind of control?
    Adam Trachtenberg replied 11 years, 10 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    November 13, 2014 at 10:32 pm
    No way to adjust the tension of b-spline points. As you’ve surmised, the only way is to add more points.
