Activity › Forums › Maxon Cinema 4D › axis arrows don’t work properly
  • axis arrows don’t work properly
    Posted by Michael Lister on January 8, 2009 at 1:25 pm
    hi all,
    stupid question. I accidently hit something which now prevents me from moving an object along an axis.
    For example when i want to move an object along the x-axis, i’d normally roll over the x-axis arrow and it’d turn yelllow…but for some reason it’s not changing colors….
    i’m able to move the object, just not along any particular axis; just able to move it all around…
    any ideas?
    thanks
    Adam Trachtenberg replied 17 years, 8 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    January 8, 2009 at 2:51 pm
    I can think of a couple things it might be. In the Viewport>Config>View options there’s a checkbox called “active axis stems”. If that’s unchecked the arrows will only tint (and be draggable) if you roll over the heads of the arrows — not the shafts.
    There’s also the F12 hotkey which temporarily disables the axes. Maybe your F12 key got stuck?
    Otherwise … might be time to trash your preferences.
