Activity › Forums › Apple Final Cut Pro › Awful results with optical flow. Tips for improving it?
  • Awful results with optical flow. Tips for improving it?
    Posted by Carlos Núñez on February 10, 2012 at 12:04 am
    I’ve been trying some slow-motion recently and I don’t know if I’m doing something wrong but my optical flow is working really bad. Everything under 20% gets really blurry and no a sense of slowmo at all.
    I’ve been recording at 60 fps and then playing it at 24.
    I use a tripod for the shots and a 50mm 1.8f
    Shuttered speed 1/60 (I don’t now if this even care when recording)
    So… I don’t know …
    Any factor to consider when trying to work with optical flow?
    David Battistella replied 14 years, 7 months ago 3 Members · 2 Replies
  • Eric Santiago
    February 13, 2012 at 6:09 am
    Are you also getting the pixel anomalies? Its like a distortion effect?
    It looks neat for some work but not all.
  • David Battistella
    February 13, 2012 at 9:19 am
    Try running the clips through cinema tools.
    You don’t need optical flow to get from 60 to 24, but maybe if you want to stretch the shot further after you have converted it to playback 600 frames per second at 24 FPS.
    Cinema tools first. Then optical flow.
    David
    ______________________________
    The shortest answer is doing.
    Lord Herbert
    https://vimeo.com/battistella
