Activity Forums Adobe After Effects Awesome logo effect – How do u create that?
  • Awesome logo effect – How do u create that?
    Posted by Hayfa Doom on August 20, 2009 at 12:38 am
    Hey you guys!
    I’m currently in Dubai with some people from work and I’ve been watching a local TV channel promoting TV shows for Ramadan or something and at the very end of every ad they run this logo that is revealed with some particle effect.
    I’ve attached the only video i could find on youtube, it’s quite retarded lol so dont bother with it but if u forward to 00:43 u can see the effect i’m talking about.
    My question is, does anyone know what this effect is called and how I may be able to create it??
    https://www.youtube.com/watch?v=ttCo0Se-ndw
    Anders Hattne replied 16 years, 12 months ago 6 Members · 9 Replies
  • 9 Replies
  • Mark Melchiorre jr.
    August 20, 2009 at 4:03 am
  • Phil Hoppes
    August 20, 2009 at 3:17 pm
    Try looking at this tutorial.
    https://library.creativecow.net/articles/kramer_andrew/reflections.php
    This is a little closer to what you are looking for.
  • Hayfa Doom
    August 20, 2009 at 10:45 pm
    Thanks so much for the replies I really appreciate it. I think the first tutorial is quite similar but they’re still a bit far off. I was talking about the logo at the end that tends to be “drawn” using particular I think. Again, thank you so much
  • Anders Hattne
    August 21, 2009 at 11:42 am
    ….what would we have done without Andrew Kramer..
    Also look at his “ring” tutorial.
    I think using a few write-on effects as a mask and parent the brush positions to the particle emitter should do the trick.
    http://www.ardillamedia.com
  • Hayfa Doom
    August 23, 2009 at 10:57 pm
    Thank you so much for that! can u actually parent brush positions to an emitter though?
  • Max Christensen
    August 25, 2009 at 11:49 am
    Hi everyone!
    Can this also be done in FCP? (The shine effect across the letters.)
    Or does it have to be in After effects?
    Best.
    Max
  • Scott Novasic
    August 28, 2009 at 5:54 am
    3d stroke with some distortion / echo could do the line effect. A simple emitter from particl illlusion or particular can create the slight particle effect after the lines finish.
    my 2 cents
    SuperNova
    Animation & Visual Effects
    Scott Novasic
    Los Angeles Ca
    web:https://web.mac.com/finaleffects
  • Hayfa Doom
    August 31, 2009 at 6:58 pm
    Thank you ever so much you guys it’s really sweet of you to reply 😉 xx
  • Anders Hattne
    September 3, 2009 at 9:03 am
    ohyeah, that’s not a problem. I just realised I might have expressed myself wrong. You would have to use an expression, but in this case it would be a matter of just using the pickwhip. In particular the z position is a separate parameter so it’s all straight forward.
    A bit late the reply.. sorry bout that..!
