Activity Forums Avid Media Composer Avid5 RGB 709
  • Avid5 RGB 709
    Posted by Richard Wirth on January 28, 2011 at 11:13 am
    To capture HDCam SR 4:4:4 in the Avid under the RGB 709 project setting, we are only given a choice of 1:1 resulting in overrun errors.
    Short of doing an external conversion to 4:2:2 (the SR deck does not have a format converter), is there anyway to get Avid to capture this material compressed (thereby creating an “off line” we can later “up-res” when ready to output?
    I’d like to get it to DNXHD 115 ideally.
    Just want to know before I pull the trigger on an external converter to get 4:4:4 material into Avid for editing.
    Richard
    Hector Berrebi replied 15 years, 8 months ago 3 Members · 2 Replies
  • Michael Phillips
    January 28, 2011 at 11:45 am
    There is no internal converter to do that while capturing a live signal, the 422 signal is expected at the source in order to capture in a compressed DNxHD format. So you will need to do that outside the Media Composer.
    Michael
    Michael Phillips
  • Hector Berrebi
    January 28, 2011 at 12:10 pm
    yup… uncompressed and a very fast raid would be the only option…
    maybe this coming NAB will introduce the much anticipated (at least for me) DNX-RGB or 444 or whatever Avid wants to call it.
    you could see how well your drives respond to prores 4×4 files via AMA then capture to a final cut system
    hector
    Hector Berrebi
    Schibber Group
    prePost Consulting
