Activity Forums Avid Media Composer AVID XpressDV 3.5 Mac won’t install on Panther OSX 10.3.9 (1008:1,-43) File not Found
  • AVID XpressDV 3.5 Mac won’t install on Panther OSX 10.3.9 (1008:1,-43) File not Found
    Posted by Buddhacam on May 3, 2005 at 6:52 pm
    Problem: I can’t get AVID Xpress DV Base Ver.3.5
    to install on Panther. I thought it would be an AVID problem, but I’ve seen the same error code list by other people on the web with different software…unfortunately with no solutions.
    Some one mention creating an extension file in the system folder but I have no further experience on this.
    Please help.
    System Specs:
    Dual 533 G4, 1.12 GB Ram
    Boot Drive 76GB, 68GB Avail.
    Data Drive IDE RAID 0 230 GB ((2)114GB Partitions)
    Panther OSX 10.3.9 Full Version
    iLife 04 Bundle with Panther
    Clean install of OS. Deleted iTunes Helper so that iLife would install. Installed DVD Studio Pro 2. Any then tried to install AVID Xpress DV 3.5 Basic version.
    I received the following error code 3/4 of the way through the install.
    “This installation requires a system folder on the destination drive. The installation has been cancelled. 1008:1,-43 File not found”
    Bill Stephan replied 21 years, 4 months ago 2 Members · 1 Reply
  • Bill Stephan
    May 3, 2005 at 7:07 pm
    What version of Mac O/S does Avid require to run Avid XpressDV 3.5? I believe it runs only on O/S 9.2, but check Avid’s web site for the real answer.
    You can’t install Avid software on just any version of O/S you happen to have. Non-linear edit software requires specific capabilities to be present in both the computer and the operating system. That’s why you see very specific configuration info for running Avid software.
    Bill Stephan
    Senior Editor/DVD Author
    USA Studios
    New York City
