Activity › Forums › Avid Media Composer › Avid Xpress Pro 5.2 Import Problems
  • Avid Xpress Pro 5.2 Import Problems
    Posted by Justin Toney on December 4, 2009 at 2:18 pm
    I can’t seem to post this on the Avid Forums so I am asking here.
    I have a show that I recorded on a DataVideo Hard Disc Recorder in .dv format. The file is split over multiple files names video1.dv video1_1.dv and so on.
    When I import that into Avid, each time there is a split in the file, I either get an audio glitch or nothing at all. However, when I view the file in quicktime, the audio is fine.
    Any suggestions on this one?
    Justin Toney replied 16 years, 10 months ago 2 Members · 2 Replies
  • David Braswell
    December 4, 2009 at 9:10 pm
    If you have QT Pro you can just export the audio for each movie as an AIFF and place them in the sequence.
  • Justin Toney
    December 7, 2009 at 2:10 pm
    But wouldn’t that be double the work? My other problem is that there are multiple cuts that I am making in this video so that brings a whole other world of problems with audio sync and so forth.
