Activity Forums Avid Media Composer Avid Xpress Character Generation problems
  • Avid Xpress Character Generation problems
    Posted by Andre on May 10, 2005 at 5:45 pm
    Hey all
    Character generator with in Avid Xpress Pro DV is giving me Grief. When I create a lower third ,it looks fine with in the CG window.
    After I save and close the window and view the lower third on the Time Line , the text is all out of alignment and it has a black line going through the top of the text….
    Have any of you seen problem??? Do you know of any solutions on how to fix it???
    Adam Duplay replied 21 years, 4 months ago 3 Members · 4 Replies
  • Dom Silverio
    May 10, 2005 at 6:11 pm
    Your user settings is probably corrupt.
    Rebuild them or use another setting.
    Next time, back up your user settings. When you get Title Tool corruption, quit out of Avid. Drop your archive user setting in the User Folder. Restart Avid. You are up and running in 1 minute.
  • Andre
    May 10, 2005 at 6:17 pm
    user setting were backed up…..created a new user profile same problem??????
  • Dom Silverio
    May 10, 2005 at 10:29 pm
    You must recreate titles that has already been corrupted.
  • Adam Duplay
    May 10, 2005 at 11:08 pm
    Try trashing your MCState files. That’s done the trick for me in the past.
    Adam
