Activity Forums Avid Media Composer avid vs final cut pro
  • Chris Bové
    May 16, 2005 at 5:29 pm
    . . . I’m curious why the Cow’s FCP thread has so many people posting tech q’s.
    I’m really curious.
    ______
    /-o-o-\
    \`(=)`/…Pixel Monkey
    `(___)
  • Dan L.
    May 16, 2005 at 6:04 pm
    What are you talking about rendering?
    The whole point of Mojo is that you don’t need to render to output with DV25
    Best,
    Dan
  • William Busby
    May 16, 2005 at 6:54 pm
    wtf? is there an echo here? 😀
  • Dom Silverio
    May 16, 2005 at 7:03 pm
    I have access to both in a daily basis, FCP/G5 definetly renders slower than Avid/xw8000.
  • Judita
    May 16, 2005 at 8:52 pm
    Wildmangoose, I don’t see why you didn’t compare Avid to other PC based software, if a PC is what you want to edit on.
    But otherwise, what Pixel Monkey said is correct. If you prefer FCP that is fine. I don’t see a question here.
  • Dan Mockensturm
    May 16, 2005 at 10:09 pm
    Wildman,
    I hear you were at NAB…
    But, I don’t believe you. Why don’t you talk a little bit more about what “tests” you performed to come to your conclusions?
    I have access to both FCP and Avid, and I’d like to verify your findings.
    Mofo
  • Stevejr
    May 17, 2005 at 12:03 am
    I went to NAB on Monday. I spent some time at AVID even more time their then at apple. I had the lady that was helping me do a test for me to see how fast it renders. I was not impressed. But I don’t want to go with Mac. I wish Express Pro was better for AVID. Avids high end stuff is awesome.
  • Stevejr
    May 17, 2005 at 12:05 am
    are you talking about avid express pro. If you are can you explain more in regards to the differences between the two when is comes to rendering. Also which is faster on 3d rendering.
  • Les Kaye
    May 17, 2005 at 12:25 am
    We’re changing over from Adrenaline HDs for the same reason…
  • Dom Silverio
    May 17, 2005 at 12:55 am
    What to say about rendering? Hard to compare when they are 2 different platforms and applications.
    XPro renders better with 3D because it has 3D features. FCP does not really. Also, there are better 3D cards on the PC side.
Page 2 of 3
