Activity Forums Avid Media Composer Avid Versions and Dongles
  • Avid Versions and Dongles
    Posted by Nate Boston on January 31, 2008 at 3:48 pm
    Hello All,
    Quick simple question – if I have an older version of Avid Express Pro (say 5.0), then I go out and buy a new copy of Avid Express Pro (say 5.6), can I use the key/dongle that came with the new version to run the old version? Or vice versa? Can I use the old key/dongle to run the new version?
    Nate
    Nate Boston replied 18 years, 7 months ago 2 Members · 2 Replies
  • Michael Hancock
    January 31, 2008 at 4:14 pm
    If you buy 5.6 you can use it to run 5.0 or any previous version. Dongles are backward compatible.
    If you buy 5.6 your 5.0 dongle will not run it–you would need to buy the upgrade from 5.0 to 5.6 and run a dongle updater on the 5.0 dongle, which will “bless” it to run 5.6.
    Michael.
  • Nate Boston
    January 31, 2008 at 6:15 pm
    Thank you for your help! That is exactly what I needed to know!
    Nate
