Activity Forums Avid Media Composer Avid transcoding
  • Avid transcoding
    Posted by Nathalie Moussa on February 18, 2015 at 8:00 pm
    Hello,
    I shot my film with a Canon C300, i transcoded my files to DNX 36 in order to edit easily with small files, however, now I want to re-transcode the edited sequence into 1:1 10b to have the best quality for the coloring. Is it possible to transcode a previously transcoded sequence? or I should create a new track and edit the project again and transcode the files into 1:1 10b?
    Thank yoou
    Nathalie Moussa replied 11 years, 6 months ago 3 Members · 3 Replies
  • Michael Hancock
    February 18, 2015 at 8:30 pm
    Duplicate your sequence. Relink the duplicate sequence to your C300 footage. Transcode the relinked C300 sequence. But 1:1 10-bit is overkill. Isn’t the C300 only an 8-bit camera?
    Michael Hancock
    Editor
  • Shane Ross
    February 18, 2015 at 9:23 pm
    It is an 8-bit camera. DNx175 is a good choice, or 145 (depending on the frame rate). 175X is 10-bit, and that is fine.
    OR…if you want lossless, just relink to the original source and consolidate. The C300 shoots XDCAM 422 in the MXF format. If you consolidate, you simply make it into Avid MXF media (no recompressing) and put it into the Avid media file structure. Zero quality loss.
    Shane
    Little Frog Post
  • Nathalie Moussa
    February 18, 2015 at 11:39 pm
    I tried to relink but each time i get interrupted by “A serious problem has occured. It is recommended to restart the system”.
