Activity › Forums › Apple Final Cut Pro Legacy › Avid to FCP color/gamma/levels shift… sometimes
  • Avid to FCP color/gamma/levels shift… sometimes
    Posted by James Weber on March 5, 2010 at 7:09 pm
    For a client, I’ll often work with an Avid editor.
    He’ll send me a video on XDCAM, in XDCAM HD1080i60 format, and it’ll look wonderful. But then, he sends me a section of the video over the internet to fix a typo or whatever, which he exports as XDCAM HD1080i60.
    When I put the section I received over the internet into my timeline, the color is drastically different than what I received on the XDCAM disc. Everything looks washed out. Blacks are not at 0, and whites aren’t at 100%. It’s next to impossible to match the colors with the Color Corrector.
    Any idea what is happening? Is this a problem on the Avid side, the FCP side, or is it just a lost in translation thing?
    Final Cut tutorials from around the web- all in one place.
    https://www.fcptutorials.com
    https://www.jamesnweber.com
    James Weber replied 16 years, 6 months ago 3 Members · 7 Replies
  • 7 Replies
  • Jeremy Garchow
    March 5, 2010 at 7:45 pm
    Check to see how fcp is interpreting the gamma. In the browser select the Show Gamma column.
  • John Pale
    March 5, 2010 at 8:38 pm
    Avid has a setting for RGB or 601/709 for export.
    I think FCP expects RGB, try both settings to be sure.
  • Jeremy Garchow
    March 5, 2010 at 8:40 pm
    That was my next line of questioning. You beat me to it!
    Jeremy
  • James Weber
    March 5, 2010 at 8:55 pm
    I sent an email to see what his settings are.
  • James Weber
    March 5, 2010 at 8:56 pm
    Neither clip shows anything in the Gamma Level Column, or with a CMD-9.
  • Jeremy Garchow
    March 5, 2010 at 9:13 pm
    [James Weber] “Neither clip shows anything in the Gamma Level Column, or with a CMD-9. “
    OK. Next is what John said.
  • James Weber
    March 17, 2010 at 10:44 pm
    Got a test clip back, exported as RGB instead of the 601/709 he normally uses. It’s a huge difference, much better, and matches the footage I import from XDCAM. Problem solved. Thanks!
