Activity Forums Avid Media Composer Avid to Avid
  • Avid to Avid
    Posted by Nate Boston on December 11, 2007 at 2:27 pm
    Hello,
    Is there an easy way to move a project + media on one computer, across a network, to another computer? Then be able to open/edit the project on the other computer?
    Is there an export setting or something? Or do I have to manually copy the files I need? I’m going from Avid Express Pro 5.6 to Avid Express Pro 5.7
    Nate
    Jeff Greenberg replied 18 years, 9 months ago 3 Members · 2 Replies
  • Jon Zanone
    December 12, 2007 at 4:30 am
    You could try consolidating. I’m not in front of my machine right now, so the details are a bit fuzzy… You could consolidate your footage, then copy the project files over…
    Jon
    “So you want to throw out the old you – but the old you is old enough to know it won’t make it better”
    Del Amitri – “Make it Better”
  • Jeff Greenberg
    December 12, 2007 at 3:33 pm
    There are two ways to do this.
    Brute force and ‘elegant’
    The brute force way is to just copy the OMFI/Avid MediaFiles folder + the project to the target machine.
    The problem here, is that you get EVERYTHING, not just your one project.
    The elegant way to do this is to go to the original machine, open the media tool, select all the clips and choose consolidate and to make a copy to a target drive.
    Then copy the project over (manually, at the desktop level) and when you get to the new machine, relink.
    Best,
    Jeff G
    Principal Instructor
    Future Media Concepts
    FMCTraining.com
    Editorsretreat.com
