Activity Forums Avid Media Composer Avid tells me clip is not in project when I match frame
  • Avid tells me clip is not in project when I match frame
    Posted by Arvid Cristina on August 1, 2014 at 5:54 pm
    So My editor is telling me when she match frames on a particular clip in her sequence, she gets the message that the clip is not in the project. However the clip very clearly is in the project. We are running a shared project on a Unity. When I open the same sequence and match frame it works fine.
    We’re working with group clips, could that be an issue?
    Running
    MC 6.5.4.2
    On a 2.266 GHz 6 Core Mac Pro Tower
    MacOS 10.7.5
    Juris Eksts replied 12 years, 1 month ago 3 Members · 2 Replies
  • John Pale
    August 1, 2014 at 9:11 pm
    Not sure what causes this, but I have seen it happen too, on unity systems. If you know what bin the clip is actually in, open it and see if it regains its marbles.
  • Juris Eksts
    August 2, 2014 at 8:39 pm
    I think you have to make sure that the bins of rushes in one of the shared projects are seen in the other shared project, not just having the clip in a shared sequence.
