Activity Forums Avid Media Composer Avid pan & zoom, video bcg, CC Effect
  • Avid pan & zoom, video bcg, CC Effect
    Posted by Jonas Hansen on October 27, 2011 at 9:09 am
    Is it possible(with workarounds) to hva a pan&zoom image ontop of a background and only grade the p&z effect. the only thing i seem to be able to do is CCE the whole thing. tried putting it in a subclip. Only grader which applies to p&z seem to be CC effect.
    Is there a way to extract the alpha from the effect? cause then I could mixdown, grade then apply the alpha on my mixdown, showing my bcg unaltered.
    Avid Symphony Nitris 5.5.1
    Mediastation Editshare
    OSX 10.6.6
    32 GB Ram, 2×2.66 GHz quad core
    Geraint Pari huws replied 14 years, 10 months ago 2 Members · 1 Reply
  • Geraint Pari huws
    October 31, 2011 at 9:28 pm
    If you want to create a matte, which will make your work around work, then do exactly the same pan and zoom move, but, replace your still with a white field, mix it down and you have an matte, you can use this then as a matte/alpha matte for your cc, or whatever effect you wish to add.
    gph
