Activity › Forums › Avid Media Composer › Avid Pan & Zoom in v8 boomeranging between keyframes
  • Avid Pan & Zoom in v8 boomeranging between keyframes
    Posted by Per Scaffidi on December 16, 2015 at 5:46 pm
    Pan & Zoom seems to be broken at the moment (I’m running v8.4). When I do a zoom + pan, the camera pulls out but also sort of boomerangs between the keyframes. So if I start on the CU of a man on the far side of a photo and zoom out to the full photo, the man will actually go offscreen for a second as the camera boomerangs out to the wide shot. There are a few other people complaining on the Avid community forums. I have a call with Avid support this afternoon to find out what the problem is, because it’s unusable (and I’m starting to cut a 18-minute doc entirely comprised of stills). Is this a universal problem in v8? Does anyone have any good plugins? I’m getting tired of the pan & zoom effect in general.
    Per Scaffidi replied 10 years, 9 months ago 1 Member · 1 Reply
  • Per Scaffidi
    December 16, 2015 at 10:47 pm
    UPDATE: I spoke with Avid tech support and this issue is supposedly being worked on by the engineering team. Bug #MCCET-19.
    I was playing around with the Boris effects Pan&zoom, and there are some things I like, some things I’m not sure about, and it’s $200.
