Activity › Forums › Apple Final Cut Pro Legacy › avid MXF to final cut 7
Posted by George Seven on July 15, 2010 at 8:41 pmHow can I import avid mxf files to final cut 7?
Do I need to convert them before importing to FCP7? If yes, is there a free software that does that?Thanks!
Bouke Vahl replied 16 years, 2 months ago 3 Members · 2 Replies -
Shane Ross
July 15, 2010 at 9:58 pm[George Seven] “ow can I import avid mxf files to final cut 7? “
With third party software.
If you want only what is used in the sequence, and the sequence itself, you use automaticduck.com.
If you want only the media, then calibratedsoftware.com or mxf4mac.com/mxf-import. These allow you to work with the footage natively.
No, they aren’t free. And no, there are no free options.
Shane
Read my blog, Little Frog in High Def -
Bouke Vahl
July 16, 2010 at 8:58 amThere are free tools to do so.
If you have an avid (or a free 30 day trial), you could export to QT.
That will give you timecode, but no reelname.
If reelname is important, you can add it using QTchange.
(either set it yourself per reel, or export an ALE and have it done in one batch)https://www.videotoolshed.com/product/42/qtchange/2
There is a video tutorial as well.
Bouke
smart tools for video pros
