Activity › Forums › Avid Media Composer › avid media composer video problems
  • avid media composer video problems
    Posted by Cristina Frunza on July 2, 2014 at 1:16 pm
    Hello
    I have a problem with Avid media composer
    i record on minidv casette sony hd 1080i and now i want to load them with a sony dvcam.
    The problem is that i can hear audio but i can’t see the video on the monitor.
    When i push the esc but to stop the capturing, i can see both video and audio and are oky.
    The problem is why i can’t see the video when is capturing? And sometimes the capturing is stoping for no reason.
    Please if is someone knows what is the problem ?
    Thank you.
    Cristina (sorry for my bad english writing)
    Andrew Kimery replied 12 years, 2 months ago 5 Members · 8 Replies
  • 8 Replies
  • Shane Ross
    July 2, 2014 at 5:16 pm
    The tape was shot as HDV…you need an HDV deck to play it back. A DVCAM or DV deck won’t do it, as they are SD only. You need specifically an HDV deck
    Shane
    Little Frog Post
  • Cristina Frunza
    July 2, 2014 at 6:00 pm
    My sony dvcam work both sd and hd. I put it on hd. It capturing but i can’t see the video on the monitor…
  • Shane Ross
    July 2, 2014 at 6:47 pm
    Ah…so it is an HDV Deck.
    Are you in an HD project?
    Shane
    Little Frog Post
  • Cristina Frunza
    July 2, 2014 at 6:48 pm
    Yes 1080i
  • John Pale
    July 3, 2014 at 7:31 pm
    Are you sure the frame rate of the video on the tape matches your project…
    For example, a tape shot at 1080i/50 will play just fine on the deck, but if you are in a 1080i/59.94 project, it won’t capture.
  • Cristina Frunza
    July 3, 2014 at 7:48 pm
    I am in 1080i/50. I can’t see the problem :(. Is the first time when i have this problem
  • Grinner Hester
    July 5, 2014 at 3:24 pm
    you have to make sure the deck has been toggled to HDV from DVcam.
  • Andrew Kimery
    July 6, 2014 at 12:20 am
    In the Capture Settings is the “Display incoming video in the client monitor” turned on?
