Activity Forums Avid Media Composer AVID MC 8.0 Newbie – Move all audio track A2 contents to A1?
  • AVID MC 8.0 Newbie – Move all audio track A2 contents to A1?
    Posted by Eddy Elliott on December 7, 2014 at 3:27 pm
    Hi guys, very new to AVID 8.0, but loving the software.
    Probably a very simple task… but how do I move an audio track of multiple audio clips to a different audio track?
    I’d like to move all clips from A2 to A1. If I select all the clips and then use the red arrow tool to move them, it only moves the clip on which i click?
    Thanks peeps 🙂
    Eddy Elliott replied 11 years, 9 months ago 4 Members · 4 Replies
  • Glenn Sakatch
    December 7, 2014 at 5:50 pm
    You should be able to draw a box around all the clips and lift them all at once.
    Another way would be to mark an in and out on the section, Ctrl C the section, and then in your source window drop down call up the clipboard contents. This will load what you just copied to the source window. use that as a source and edit it to the audio track you want.
    Glenn
  • John Pale
    December 8, 2014 at 3:18 am
    Another way…
    Put in/out around the whole track. On a Mac press Cmd-X to cut, then target A1 then hit Cmd-V (paste).
    On PC, substitue Ctl for Cmd.
  • Pat Horridge
    December 9, 2014 at 8:03 am
    Or drag the sequence to the source monitor. Make a new sequence. Patch the tracks as required. A2 to A1 and video if needed and then edit the whole thing across.
    Pat Horridge
    Technical Director, Trainer, Avid Certified Instructor
    Free online Tutorials at VET digital media academy online https://vimeo.com/channels/752951
    VET
    Production Editing Digital Media Design DVD
    T +44 (0)20 7505 4701 | F +44 (0)20 7505 4800 | E pat@vet.co.uk |
    http://www.vet.co.uk | Lux Building 2-4 Hoxton Square London N1 6US
  • Eddy Elliott
    December 9, 2014 at 10:56 pm
    Thanks for all the responses guys. All methods seem to work. Many thanks!!
