Activity › Forums › Avid Media Composer › AVID MC 7 Error “swdc codec interface task consistency check failure” – except when adding Timecode Burn-In
  • AVID MC 7 Error “swdc codec interface task consistency check failure” – except when adding Timecode Burn-In
    Posted by Philip Rämsch on September 27, 2015 at 4:17 pm
    Hello community,
    got a strange version of our good old “swdc codec interface”-error.
    I get the error when trying to mixdown my sequence.
    When i add an Timecode-Burn-In to a new Video-Track in this sequence the mixdown works fine.
    Is this because Avid now renders all the effects in the sequence? Or does Avid only render the Burn-In?
    I takes an hour for doing a mixdown of a 90 minutes sequence (DNxHD 36), when the timecode is added.
    Thank you for your reply!
    Philip
    Philip Rämsch replied 11 years ago 1 Member · 0 Replies
  • 0 Replies
