Activity Forums Avid Media Composer Avid MC 6 and BMD DeckLink HD Extreme
  • Avid MC 6 and BMD DeckLink HD Extreme
    Posted by Ted Moore on November 28, 2011 at 11:18 pm
    I’m not sure where to post this, so…
    I’ve just upgraded my OS to 10.7.2 as well as my MC from 5.5 to 6… All that was left was adding the Desktop Video application, available from BMD, and get back to work…
    I’ve since lost all of my audio playback out of Avid and is still available for Premiere 5.5, FCP 7, Spotify and literally anything else I load…
    short of removing the card or reinstalling Avid MC 6 are there any tips anyone has for getting it working again?
    Ted
    FoopsDesign.com
    Delivering Creative Stories
    Robin replied 14 years, 10 months ago 5 Members · 7 Replies
  • 7 Replies
  • Oliver Peters
    November 29, 2011 at 12:51 am
    Your audio playback from MC6 is only available via the Decklink. Is that where you lost it or are you referring to core audio from the built-in outputs? You can’t access those from MC6 with the card installed.
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
  • Mike Most
    November 29, 2011 at 4:47 am
    When using a Decklink card with MC6, the audio is sent out embedded with the video on the SDI feed. It should also be available from the audio outputs of the Decklink card. It will not be available on the computer’s line outputs.
  • John Pale
    November 29, 2011 at 1:30 pm
    Avid doesn’t output audio from the computer with the Decklink card…only through the card.
    The computers built in audio would be out of sync.
  • Ted Moore
    November 29, 2011 at 2:24 pm
    I need to buy a few things so I can have my audio back again is what it sounds like to me…
    Thanks for your replies gentlemen…
    FoopsDesign.com
  • Robin
    November 30, 2011 at 4:39 am
    Is there any way to turn off the Decklink card without uninstalling the driver or removing the card from the MacPro?
  • Oliver Peters
    November 30, 2011 at 2:11 pm
    No. MC uses the card, if present.
    – Oliver
    Orlando, FL
  • Robin
    November 30, 2011 at 3:22 pm
    I feel a feature request coming 😀
