Avid MC 3.5.4 – CONSISTENCY CHECK FAILURE Error
Hi –
Recently our editors have started getting this error in Media Composer 3.5.4.
(The number associated with the message changes each time)
This seems to happen when scrubbing around a timeline. Unfortunately we are a Final Cut based place and I can’t seem to find much info on this error so I’m not sure how to attack it.
This happens in every project (RED, DV etc). Audio comes in from the soundy as wav files which I believe get imported by simply being dragged in.
We run Apple XSAN (and have the Avid MediaFiles folder located on the root of that disk) and I can replicate this error on all our machines. They are various Mac Pros all running the same disk image (OS X 10.5.8 with QT 7.6.4). The output hardware is a Mojo SDI.
I have an upgrade to 4.0.2 but not sure if that is going to fix my issue and I can’t break it during an edit.
Thanks for any help –
Andrew
