Activity › Forums › Avid Media Composer › Avid import of FCP files with AMA?
  • Avid import of FCP files with AMA?
    Posted by Lawrence Marshall on April 30, 2010 at 2:09 pm
    Hi all –
    An Avid production company would like me to digitize a live event directly to hard drive, which they would then edit. Recording would be 720p 30 or 720p 60. But I am Final Cut-based, digitizing with a Kona LHi card. Will Avid’s AMA plug-in be able to read my FCP Quicktimes directly and let the Avid editor begin immediately, or will the FCP Quicktimes have to be “unwrapped” and/or transcoded again by Avid? If only a certain Quicktime file can be recognized by Avid’s AMA plug-in, what would be the best codec to digitize to? Standard-vanilla 720p? Apple ProRes? (the Kona card in FCP can digitize to seemingly a billion different Quicktime formats, but not Avid-specific Quicktimes…)
    Larry Marshall
    Lawrence Marshall replied 16 years, 5 months ago 3 Members · 3 Replies
  • Job Ter burg
    April 30, 2010 at 2:56 pm
    Currently AMA does not support Quicktime. So yes, it would require a “regular” import from ProRes into DNxHD.
    MC5, just announced at NAB, to be released June 10th, _will_ support QT over AMA (and therefore will explicitly allow users to use ProRes files captured with FCP and such).
  • Kris Anderson
    May 1, 2010 at 7:52 am
    Can you not just hire an Avid rig for the job? They aren’t that expensive. Otherwise you’ll have to wait until June for MC5, as Job said.
  • Lawrence Marshall
    May 1, 2010 at 3:27 pm
    Problem solved. Sort of. Client decided they would rather have the program recorded to tape. Thanks for the AMA update for June.
