Activity › Forums › Avid Media Composer › Avid forcing me to transcode DNxHD and Prores
  • Avid forcing me to transcode DNxHD and Prores
    Posted by Brandon Ruiz on October 30, 2013 at 4:22 pm
    Hi guys, Avid newbie here. Just switched over from Premiere and I can’t figure out why Media composer 7 requires a transcode for DnxHD and Prores. I’m doing a drag and drop import into my bin. Do I have some setting wrong?
    James Patterson replied 12 years, 11 months ago 4 Members · 11 Replies
  • 11 Replies
  • Brandon Ruiz
    October 30, 2013 at 4:44 pm
    Found a solution here https://forums.creativecow.net/thread/45/871678
    Looks like that helped but is there any way to speed it up any more?
  • Shane Ross
    October 30, 2013 at 5:34 pm
    Well, first off know that Avid isn’t like Premiere. Avid really wants the media you import to be converted to an Avid friendly editing format. Premiere doesn’t, as you know…it works with media natively. So if you are going to use Avid Media Composer, you need to do what it wants.
    First off…don’t import by dragging into a bin…that INSTANTLY converts the footage. If you want to access it natively, you use AMA. LINK TO AMA will bring in the media natively…make a clip that points to the media, untranscoded. Now, if you want, you can try to edit that natively. Avid MC can do that…but it is far from optimal. It might be very sluggish.
    The best thing to do would be to then highlight all the clips you brought in via AMA and TRANSCODE to DNxHD.
    Shane
    Little Frog Post
  • Brandon Ruiz
    October 30, 2013 at 5:42 pm
    Import via AMA. Tried it and it seems to be working fine natively. Thank you!
  • Daniel Frome
    October 30, 2013 at 6:07 pm
    Small tip to speed up your workflow — hold down alt/option while dragging the file into a bin. This will AMA link the file instead of the traditional import.
  • Shane Ross
    October 30, 2013 at 6:15 pm
    GOOD ONE Daniel…I didn’t know that!
    Tweeting this tip…
    Shane
    Little Frog Post
  • Daniel Frome
    October 30, 2013 at 6:17 pm
    and I follow you on twitter, so I’ll be watching 😉
  • Shane Ross
    October 30, 2013 at 6:18 pm
    What’s your handle? I need to attribute that to you!
    Shane
    Little Frog Post
  • Daniel Frome
    October 30, 2013 at 6:19 pm
    danielfrome
    Creative, I know 😉
  • James Patterson
    October 30, 2013 at 6:21 pm
    Is this new to 7? I’m still in 6.5 land and it doesn’t work.
    Best
    Paddy
  • Daniel Frome
    October 30, 2013 at 6:22 pm
    Ya it’s 7 only.
