Activity Forums Avid Media Composer AVID Express Audio Question
  • AVID Express Audio Question
    Posted by Joe Quartararo on December 30, 2007 at 8:37 pm
    I’m not too savvy when it comes to audio and I have an audio clip with a vocal, where the background noise is too high. There’s a flowing river, and it is too high to match up with the ambience track I’ve got for the scene.
    If I were to noise gate it, or compress the clip, how would I manipulate the controls? Just to lower background noise enough.
    I’m terrible when it comes to this, and any help would be appreciated, greatly. Thanks
    Jon Zanone replied 18 years, 9 months ago 3 Members · 2 Replies
  • Joe Womble
    December 31, 2007 at 3:48 am
    How long is the clip? Is it just a sentence or two? If so, you could ADR or re-record the vocal, then add a track of the river and mix the two so it sounds like you intended.
    Regards,
    Joe Womble
  • Jon Zanone
    December 31, 2007 at 12:30 pm
    Joe is right. Taking background noise out requires pretty sophisticated software. I’d use Sound Forge with a Noise Reduction Plug-in. If re-voicing is out of the question and you don’t have Sound Forge, I’d try a parametric EQ in the audio suite and try to pin-point the river. You could then mix in the original clip. Keep in mind it will never sound like the rest of your clips.
    Jon
