Activity Forums Avid Media Composer avid export
  • avid export
    Posted by Rich Klein on October 8, 2006 at 4:15 am
    I am getting an error message when I try to export a sequence using the same as source setting. I have used this many times before so I don’t understand the error. I am using quicktime movie. The error is “Unable to export the bin. Exception: Parameter error! This export format may require audio or video tracks.” The tracks are selected and i have tried all settings that I can. It will exportt using compression settings. I want to use the highest quality possible. Any sugestions?
    Rich Klein replied 19 years, 11 months ago 3 Members · 5 Replies
  • Michael Phillips
    October 8, 2006 at 4:59 pm
    Does your sequence have any mixed formats or sample rates?
    Michael
    anything 24fps
  • Rich Klein
    October 8, 2006 at 8:35 pm
    Thanks for the response Michael. I have tried sequences with straight cuts and no effects at all. I get the same error. I can export with compression settings but I can see stepping and tearing on the DVD’s. I don’t know if that’s from the camera (Canon GL2 set to SP and auto settings) or from the MySonic DVD software but I’m disappointed with the quality.
  • Erik Pontius
    October 9, 2006 at 5:25 am
    I’ve seen similiar things. You might check your export settings and see if “use marks” and “use enabled tracks” are set. If so either uncheck the options or set an in/out point from begining to end of your sequence and double check to make sure that all your tracks that you want exported are enabled.
  • Erik Pontius
    October 9, 2006 at 5:29 am
    I might be stating the obvious, but make sure that you are exporting the sequence by making sure that the timeline window is active, before going to file/export….since it might actually be attempting to export the contents of a bin.
  • Rich Klein
    October 10, 2006 at 3:03 am
    I’ve tried all of those things. I might have a virus affecting the avid software. I’m getting an Avidstartup error when I boot the machine. Just a guess. It works when I use the Sorenson compression but not when I use the same as source settings. I might have to reload the software to see if this fixes it but I have projects I need to finish first. What is the best quality for using in DVD creation?
