Activity Forums Avid Media Composer avid error AMA failed changing the clips to the desired quality prior to consolidate. Consolidate aborted.
  • avid error AMA failed changing the clips to the desired quality prior to consolidate. Consolidate aborted.
    Posted by Edo Brizio on April 29, 2014 at 6:38 pm
    I’m on Avid 7.0.3 and in order to export an AAF I’m transcoding to DNXHX and I get this error:
    Any recommendations?
    I isolated the AMA clips in a bin and tried everything possible …
    I did this in the past and it worked.
    thanks
    Edo
    Will Scothern replied 11 years, 10 months ago 3 Members · 5 Replies
  • Michael Phillips
    April 29, 2014 at 8:33 pm
    Are you doing an embedded AAF or a “link to” AAF? I make AAF “link to” all the time with a mix of codecs and there is no need to consolidation or transcode. Just as a test, if you are doing “link to”, try checking the “AAF Protocol” to be active and try again.
    Michael
  • Edo Brizio
    April 29, 2014 at 8:56 pm
    It’s a AMA issue, I need to transcode to DNX HD to export any AAFs.
    I fixed the 6 clips that were causing problems narrowing down the sequence AMA relinking those files, is now transcoding, hope wil get to the end)
  • Michael Phillips
    April 29, 2014 at 8:59 pm
    If you use AAF “Edit Protocol” with 6.5 and earlier there was no need to transcode to export an AAF. In v7 I don’t need to transcode to create full version of AAF as long as it’s a “link to” and not embedded. Not sure why you need to transcode.
    Michael
  • Edo Brizio
    April 29, 2014 at 9:10 pm
    AMA linked files require to transcode prior to export an AAF …that’s the message I get from Avid even with the link to selected.
  • Will Scothern
    November 1, 2014 at 4:46 pm
    Did you get a solution in the end? I’m having the same problem currently and can’t find a way around it.
    I’m thinking I may just have to consolidate the reference media as a whole to get it to work, or do a straight transcode.
