Activity Forums DaVinci Resolve Avid EDL / timecode match
  • Avid EDL / timecode match
    Posted by Stig Olsen on October 10, 2011 at 6:53 pm
    Im doing a project on RED, exporting EDL (16) from Avid into Resolve.
    The 3rd-files are loaded, but the timecodes on every clip is not correct.
    I have checked the original files in Avid and they are the same as the EDL list. Resolve show other timecodes than the original files.
    Any ide what I have done wrong?
    My solution is to change the timecodes in Resolve to match the EDL, but thats not a proper workflow for longer projects.
    Stig
    Mike Most replied 14 years, 10 months ago 4 Members · 6 Replies
  • Joseph Owens
    October 10, 2011 at 7:22 pm
    Are the frame rates in all your configurations consistent?
    jPo
    You mean “Old Ben”? Ben Kenobi?
  • Stig Olsen
    October 10, 2011 at 7:31 pm
    Correct.
  • Robert Due
    October 10, 2011 at 8:55 pm
    Is your timeline conformed at 23.98? If it is at a diffeent rate than the offline, that could cause the picture to shift.
    Robert Due
    Editor / Colorist
    INDEPENDENT EDIT
  • Stig Olsen
    October 10, 2011 at 9:22 pm
    Its conformed at 25, and the clips are also shot in 25 frames.
  • Robert Due
    October 10, 2011 at 10:01 pm
    Perhaps you need to generate the EDL with the Time of Day TC. That may be under the Aux Timecode column in Media Composer. Maybe that will link up to the right picture in Resolve. Worth a try?
    Robert Due
    Editor / Colorist
    INDEPENDENT EDIT
  • Mike Most
    October 10, 2011 at 10:11 pm
    Red files carry two time codes, time of day and absolute. Make sure you’re using the same set of time codes in both Avid and Resolve.
