Activity › Forums › Avid Media Composer › Avid Editor Salary
Avid Editor Salary
Posted by Dvguy1 on April 1, 2005 at 4:25 amWhat would be a fair salary for a full time Avid Editing position for a cable network?
Grinner Hester replied 16 years, 8 months ago 13 Members · 21 Replies -
Haze
April 1, 2005 at 4:37 pmNo one can give you an accurate number. There are far too many variables: quality of your reel, type of industry (gov’t, advertising, corporate) and basic suppli & demad (how many Avid editors are in your market).
The other thing is that the term ‘Avid Editor’ is a fairly broad description. What flavor Avid? Symphony, Nitris, Composer, XDV or FreeDV.
I would hit some web sites for an indicator of what the market will pay for your skill set.
mandy
productionhub
craigslist
entertainmentjobs?
etc. -
Mark Anderson
April 1, 2005 at 10:16 pmthat’s the problem, none of those lists or want ads ever list salaries, or salary ranges. they ask you to provide a range more often then not. no one can give the guy even a clue. yes, there are ranges, but let’s get some specifics.
me–from cincinnati to chicago, over 15yrs television experience currently union editor salary range with overtime 57-62,000. i know a guy in dayton ohio just starting out with a cable system who was offered 28,000.
Shane Ross
April 1, 2005 at 10:37 pmI am a Union editor in Los Angeles, and the Union base scale here is $2365.00 per week, with lower scale for smaller budget productions (they go as low as $1585.00). I have worked on productions both union and non-union that ranged from $1500 (low on the totem pole cable networks) to $3000 (network reality TV, Union Narrative TV) per week.
But, I am in Los Angeles and this is THE market…plus costs out here are high.
What you need to do is fine out what the median is for your area.
Oh…and the edit system has NOTHING TO DO with your rate. They are hiring you for your editing ability, not for your skill with an edit system.
Haze
April 2, 2005 at 12:08 am“Oh…and the edit system has NOTHING TO DO with your rate. They are hiring you for your editing ability, not for your skill with an edit system.”
This has some truth. From a freelance perspective it’s absolutely true, but in regards to a staff position it doesn’t have legs. Most employers don’t want to take the risk or spend money training someone. They need someone that can jump right in and start cutting. If you’ve nvever cut on a DS/Nitris then you’re not even considered for the job. So even if you can out cut Murch using XDV it doesn’t matter – there’s no offer on the table. It doesn’t happen. I’ve never seen a job post that said, “Avid DS editor needed – no experience necessary”.
Dom Silverio
April 2, 2005 at 2:12 amActually it is probably worse for freelance in my experience. When you are hired for 8 or 12 weeks that is what you are hired and budgeted for. There is week for refresher or training. At least with permanent staff, if you are replacing another person they may take you in because of your reel and as a junior editor until you get your legs unnder you.
.02
Dvguy1
April 2, 2005 at 2:09 pmI am doing some freelance work for the company at a rate of $45 and hour editing on a Symphony and some After Effects work. Does that help?
Mark Raudonis
April 2, 2005 at 3:56 pm[Haze] ” Most employers don’t want to take the risk or spend money training someone. They need someone that can jump right in and start cutting.”
Not necessarily true!
When we threw out our Avids and switched to a Final Cut Pro system networked with X-SAN, we took the time and spent the money to train 45 former Avid editors on our new FCP systems. This wasn’t cheap, but it’s a confirmation of the concept that we hire “editors”, not button pushers. In “The Real World”, it’s always about story. I’ve NEVER received a call from a viewer who said, “That’s a great show… what kind of NLE did you use?”
This most significant factor in salary is the budget of the project you’re working on. The higher the budget, the better the rate.
Mark
