Activity Forums Avid Media Composer Avid DS Audio Timewarp – Out of Sync Tracks
  • Avid DS Audio Timewarp – Out of Sync Tracks
    Posted by Jeff Winston on October 6, 2008 at 6:59 pm
    I was timewarping a 59.94 item with 8 audio tracks in DS v8. I captured the audio as 8 mono channels. After the timewarp the tracks were out of sync. Does anyone have an answer about this? Thanks!
    Jeff Winston
    Tony Quinsee-jover replied 17 years, 11 months ago 2 Members · 1 Reply
  • Tony Quinsee-jover
    October 8, 2008 at 11:47 am
    Hi Jeff,
    By default DS will find the most ‘pleasing’ method of time-compressing an audio clip. It will reduce the length of gaps as its first priority as this will have the most minimal impact on the result. This will give you exactly the audio duration you’ve set but will give different results on different clips.
    By altering the CrossFade and Minimum Pitch sliders you will get different results but you’ll never have two timewarped audio tracks to be sample-accurate the same as each other.
    For lots of help and advice on DS, take a look at the DS-L Google Group at https://groups.google.com/group/DS-List
    Regards,
    Tone 🙂
