Activity › Forums › Avid Media Composer › Avid DNxHD codec configuration window won’t allow Alpha selection
  • Avid DNxHD codec configuration window won’t allow Alpha selection
    Posted by Michael Powers on November 2, 2010 at 3:32 pm
    As Avid editors, I am guessing you appreciate the speed with which Avid DNxHD encoded quicktimes import over image sequences or other non-Avid encoded containers.
    As a Mograph/Animator, I can’t export a DNxHD Quicktime with an alpha channel because the Avid codec does open a full configuration window and the alpha radio buttons don’t function. see: https://community.avid.com/forums/t/72403.aspx?PageIndex=1
    This occur when using using applications like AfterFX and Sony Vegas.
    If anyone knows of a workaround besides opening Quicktime pro and exporting, I’d love to know – because I like giving our editors the easy/quickest format for importing.
    If not, maybe you can complain to Avid and help motivate them to fix this glaring problem.
    Note: this was not a problem with XP-64, but Think this is a 64-bit app related problem.
    Windows 7, HP xw8800, 16GB RAM, NVidia Quadro FX 4600
    Thnx
    Michael Powers
    Creative Director, Animation
    Crameronline.com
    Sam Foster replied 12 years, 7 months ago 4 Members · 3 Replies
  • Richard Sanchez
    November 9, 2010 at 8:03 pm
    What version of Avid Quicktime Codecs LE are you using? It sounds like you were using a version older than 2.3 Here’s a link to download the newest version https://avid.custkb.com/avid/app/selfservice/search.jsp?DocId=372311
    That said, I still occasionally have issues exporting Quicktimes with Alpha Channels from After Effects to Avid and find the most reliable method to be exporting to Apple Animation with Alpha (or as After Effects calls it, Lossless with Alpha).
    Richard Sanchez
    North Hollywood, CA
    “We are the facilitators of our own creative evolution.” – Bill Hicks
  • Steven Javitz
    November 8, 2013 at 2:09 am
    I had the same problems with the Avid DNxHD Codec Configuration window on Sony Vegas Video. Radio buttons would not work, and the drop down list of frame rates and bit rates was not available on version 12 of vegas. I realized it was because I had the old AVID DNxHD codec installed, and that they would refuse to update when trying to install the new avid dnxhd codecs.
    Note the title of my old version of the configuration window: “Avid DNxHD Codec Configuration window – v2.2.1” *should be v2.3.7
    Solution: Overwrite the old codecs manually.
    After “installing” the new Avid codecs, I think they ended up in this directory C:Program Files (x86)QuickTimeQTComponents
    But they should go into this directory and replace the old 2010 codecs C:Program Files (x86)QuickTimeQTSystem
    The new codecs should have a date of October ‎17, ‎2011
    By the way, the files are called something like this: AvidAV1xCodec …. and there are 8 files. Once I moved them over manually, and restarted Sony Vegas, it all worked!
    -Steven
    https://www.crossingsouth.com
  • Sam Foster
    February 20, 2014 at 5:34 am
    Hi, recently I started using the DNxHD codec (recent version) with vegas and had the same sort of problem (except it was that the configuration window was too small to correctly display the render settings in the drop down menu e.g. resolution, bitrate) and it doesn’t allow resizing. My solution was to use a program called ‘Resize Enable’ which when activated allows you to resize any window regardless of option. Once you resize the window all functions should automatically space themselves out like a normal resize. I downloaded the program here…
    https://www.digitallis.co.uk/pc/downloads.html
    Hope this helps,
    Sam.
