Activity Forums Square Box CatDV Avid DNx fails to play in Big Sur using Pegasus 13.0.14
  • Avid DNx fails to play in Big Sur using Pegasus 13.0.14
    Posted by Robb Harriss on March 10, 2022 at 2:34 am
    Well this used to work. I used to be able to play my Avid videos but now I’m getting the (1 failed to open movie) error. I’m pretty sure it still works if I drop back to Catalina, but at this point I don’t remember. Too many changes and too much water under that bridge. Trying to select another player inside Pegasus doesn’t change anything. Of note, doing another import doesn’t help. The audio comes in but there’s no picture. Not running any of the Calibrated plugins. The need for such was supposedly eliminated a couple versions ago in Pegasus.😖
    Robb Harriss replied 4 years, 6 months ago 1 Member · 1 Reply
  • Robb Harriss
    March 10, 2022 at 7:30 pm
    well it’s working on the other machine, running high Sierra. So I’m not sure what’s different.
