Activity › Forums › Avid Media Composer › Avid Automatically accessing files in a BPAV folder
  • Avid Automatically accessing files in a BPAV folder
    Posted by Peter Groom on March 15, 2012 at 10:13 am
    Ive noticed that now when i put a card in my slot with a bpav folder structure on it, avid is automatically accessing and importing the files into the project.
    is there a menus thats got changed. I think Id rather be specifically telling avid to perform functions, not automatically.
    Theyll be adding an “automatically edit, mix grade and make everything perfect” button next.
    Peter
    Post Production Dubbing Mixer
    Peter Groom replied 14 years, 6 months ago 4 Members · 4 Replies
  • Gary Hazen
    March 15, 2012 at 2:46 pm
    Turn off AMA.
  • Brendan Maghran
    March 16, 2012 at 5:53 am
    Unchecked auto mounting in ama settings
  • Pat Horridge
    March 16, 2012 at 8:13 am
    Yes this auto mount feature is a real pain. Mount a USB stick with a load of media and Avid AMAs the lot. Mount a network share and the same happens.
    Unfortunately it’s all or nothing. If you turn of auto mounting all AMA. Functionality is turned off
    But AMA mounted clips aren’t imported. Only master clips are created no content is moved or created.
    So it’s not so bad. And if you need that AMA content it’s there. Except of course you plan was to move it to a sensible place first!
    Pat Horridge
    Technical Director, Trainer, Avid Certified Instructor
    VET
    Production Editing Digital Media Design DVD
    T +44 (0)20 7505 4701 | F +44 (0)20 7505 4800 | E pat@vet.co.uk |
    http://www.vet.co.uk | Lux Building 2-4 Hoxton Square London N1 6US
  • Peter Groom
    March 16, 2012 at 10:39 am
    HI
    yes i have disabled it.
    My solution will have to be leave it off, then when i want it turn on, ama mount, transcode the media and disable it again.
    peter
