Activity › Forums › Avid Media Composer › Avid audio import error?
  • Avid audio import error?
    Posted by Juan Juig on October 18, 2016 at 11:51 pm
    Hello,
    I have imported an audio clip, recorded with my Zoom h4n recorder. The clip is 2 minutes long. There are two parts of the clip in which the audio is clipped and there is a frame or a few frames of spiked noise. At first I thought that something was wrong with my recorder or with my SD card.
    However it turns out that when I listen to the clip with audio players or when I import it into another editing tool, there seem to be nothing wrong with the clip. There are no “bad” frames of spiked noise. The clip is flawless.
    I made sure that the audio settings are same as the source: 48khz 24bit.
    Has anyone else encountered this problem? What is the cause of this and what is the solution?
    Michael Phillips replied 9 years, 11 months ago 2 Members · 1 Reply
  • Michael Phillips
    October 19, 2016 at 12:58 pm
    What happens if you right click and “set audio gain” to something like -10? CD imports come in hot a lot as well. Something to try.
    Michael
