Activity › Forums › DaVinci Resolve › Avid Artist Color and DaVinci 8
Posted by David Austin on June 30, 2011 at 2:55 pmMight be a bit early, but has anyone had a go with Resolve with Avid Artist Color?
Ronen Pestes replied 15 years, 2 months ago 6 Members · 6 Replies -
Jörgen Persson
June 30, 2011 at 5:40 pmI upgraded the EuControl software (v2.6) and the firmware for the panel and then I got everything to work.
An XML from an old FCP project I graded with Apple Color translated perfectly into Resolve 8. The Red footage set to redcolor2 and redlogFilm looked spectacular after a quick grade.I’m really happy with how easy and powerful it is.
(We use the GTX285 in a 8-core 2.4 MacPro attached to xSan via Fibre Channel) -
Nigel Thompson
June 30, 2011 at 10:21 pmGreat to hear…..plan on getting both soon.
Question about V8 tho… Is it that it performs better with the more GFX cards you feed it.
so if i stick another openCL card in my macpro performance will boost ?
have an 8core 2.26 with a GT 120
RED,DSLR, FCS and more,
High End, Production & Post Production
in the Caribbean
http://www.bistt.com -
Peter Chamberlain
July 1, 2011 at 12:53 amThe OpenCL implementation is limited to a single image processing card. If you want more performance add more Quadro 4000 cards, which are CUDA based. You can have up to three in the Mac OS X and 16 in Linux.
Peter
Nigel Thompson
July 1, 2011 at 1:59 amcool thanks peter.
My next question to BMD is will they support AJA products at all in resolve …?
my kona LHi is a lovely piece of hardware and i truly hope BMD makes resolve an open piece of software that will use it ……If not im screwed because i need pro output to grade. and will have to stay with color for a while, till i figure out what to do…
in the Caribbean
Nate Weaver
July 2, 2011 at 5:08 am -
Ronen Pestes
July 3, 2011 at 4:47 pmHi Jörgen,
Can you give more information about the Avid Artist panel and the use with the Resolve. I can’t find any real documentation or videos regarding the work-flow.
How easy is the use of it with the Resolve? Do you have access to all the menus ? can you customize buttons? can you compare it to the wave panel?
maybe you can upload some images .. 🙂
Thank you in advanceRonen Pestes
Editor and Finishing Artist
https://www.ronenpestes.com
