Activity Forums Avid Media Composer avid and AJ-HD1200A
  • avid and AJ-HD1200A
    Posted by Dirk Teubler on September 19, 2005 at 4:38 pm
    hi there, i have some questions about avid-express pro HD.
    is it possible to capture from the panasonic AJ-HD1200 over firewire,
    reeding 60p and edit this in a PAL-confirm timeline, like 25p or 50i ?
    or, does avid express pro hd can capture a slowmotion, writen in 60p?
    anyway, my english is not the best…i hope you understand my problem…
    at this time we are working with final cut pro HD and we want to buy an avid system for a better workflow with our television stations.
    the avid system will be on a pc-system, also maybe on a mac-system…but the mac can wait…
    Juan Salvo replied 21 years ago 3 Members · 2 Replies
  • Bill Stephan
    September 19, 2005 at 5:40 pm
    Not possible until Xpress Pro HD 5.5 is released. Even if your 1200A has the downconverter board, you cannot downconvert HD tape to the Firewire port. So you would need to capture and edit HD media.
    Bill Stephan
    Senior Editor/DVD Author
    USA Studios
    New York City
  • Juan Salvo
    September 20, 2005 at 6:20 pm
    Actually you can it’s in the DIF menu settings, i think it’s the 800’s. You need to set the IEEE1394 standard to DV, and you might need to slow the transfer rate to S100.
