Activity Forums Avid Media Composer AVID Adrenaline HD question
  • AVID Adrenaline HD question
    Posted by Mark Baird on February 28, 2006 at 11:06 pm
    In setting up a “simple” Avid Adrenaline HD system to capture and layback to tape from either Sony HDCam or from Panasonic “Varicam” decks (via HD-SDI in both cases), is it absolutely necessary to have a tri-level sync generator? What am I giving up if I don’t have one? Etc.
    Thanks for any info.
    MB
    Mark Baird replied 20 years, 7 months ago 2 Members · 2 Replies
  • Dom Silverio
    March 1, 2006 at 12:16 am
    It all depends on the frame rate/format you are handling. Rule of thumb is if there is a frame rate conversion going on (say 24p to 60i) you will need it. However if you are working strcitly with interlaced format that is 59.94/29.97 a regular blackburst will work.
  • Mark Baird
    March 1, 2006 at 7:37 pm
    Thanks for the info.
    MB
