Activity › Forums › DaVinci Resolve › Avid AAF to Resolve… Geez I feel stupid
  • Avid AAF to Resolve… Geez I feel stupid
    Posted by Eric Chase on August 5, 2011 at 1:13 am
    I have a feature Red show on AVID and I’m trying to AAF myself in conform hand having no luck. I do get it to import with red ‘x’s over the whole timeline. I get a familiar number tag at the top right, but it doesn’t make the correct edit when I color.
    What’s the right settings for Avid and Resolve? Please someone help me, I’m on a short schedule with this one.
    Eric Santiago replied 15 years, 1 month ago 3 Members · 8 Replies
  • 8 Replies
  • Eric Santiago
    August 5, 2011 at 2:21 am
  • Eric Chase
    August 5, 2011 at 3:28 am
    I read everything there and I still don’t understand the right settings to import an Avid session into Resolve.
  • Eric Santiago
    August 5, 2011 at 12:04 pm
    Once you export the proper AAF, load the AAF in Resolve.
    Itll ask where the original R3D files are so make sure you direct it to the top root of that.
  • Eric Chase
    August 5, 2011 at 2:37 pm
    Sorry for being dense here.. I’m on MC 5 mac
    How do you output a aaf “correctly”?
    and
    Should’t you put the files in the media pool first?
  • Jules Bodenstein
    August 5, 2011 at 2:48 pm
    I would suggest double checking the pathname set up on the timeline control options in the config to make sure its reading the reel name of the footage correctly.
    Gaz Evans
    Workflow Technician
    The diROOM
    https://www.diROOM.com
  • Eric Santiago
    August 5, 2011 at 3:46 pm
    If you use the same R3D and ingest into Avid with AMA leaving all folders structures intact (original R3D folders) then all you need to do is export as AAF and make sure to check on “AAF Edit Protocol”.
    Now load that AAF doc in Resolve and select the original source clips.
    Just in case, make sure to have all tracks hi-lighted in Avid before exporting to AAF.
    We use Avid MC Nitris DX on Mac here.
    We make copies of the R3D files and so far no problems reading from different copies.
  • Eric Chase
    August 5, 2011 at 7:56 pm
    So be clear… The AVID session footage is MXF. I’m trying to color the mountain of Red files spread cross 3 different drives.
    What would be the right settings for AVID AAF, and the right settings for Resolve?
  • Eric Santiago
    August 6, 2011 at 3:15 pm
    I would need someone else to chime in on the MXF part.
    Ive only been going from R3D > Avid AMA > Avid basic edit > Export AAF.
    Im sure there is a workflow where you set all your R3D>AMA clips into a Sequence then Transcode for ease of edit but I havent gone that route to date.
