Activity Forums DaVinci Resolve Avid AAF round trip problems
  • Avid AAF round trip problems
    Posted by Chris Coote on August 21, 2014 at 7:54 pm
    Hi
    I am trying to import an AAF of dailies (DNXHD 45) made in Resolve (V11) into Avid (Symphony v6.04)
    I get these errors every time (see attachments):
    If I click “continue” through the errors, I see the clips in the bin with V1 A0-2 in the tracks column.
    They wont play though and keep giving errors.
    However, if I open the media tool and drag the clips into a bin they open fine. Under “track” it says V1 A1-2,
    or V1 A1-8 – like it should, depending on my resolve audio export settings. These clips play fine.
    This makes me think that the DNXHD files are fine – it’s just the AAF that Avid doesn’t like for some reason.
    Anybody seen these error messages? Am I losing any metadata by dragging from the media tool, instead of importing the AAF?
    I have tried using V7 of Avid with the same results. I have tried different combinations of export settings
    using the Avid AAF round trip preset in Resolve as a starting point with no luck.
    The original footage is Sony XAVC with 8 channels exported as DNXHD 45.
    Chris
    Chris Coote replied 12 years ago 2 Members · 2 Replies
  • Joseph Owens
    August 25, 2014 at 5:24 pm
    [Chris Coote] “Anybody seen these error messages? Am I losing any metadata by dragging from the media tool, instead of importing the AAF?”
    Similar error messages… but not the same. I got errors somewhat like this when I was trying to deal with some XDCam footage without the proper decoder installed, but I don’t think this is your issue.
    I doubt you would lose any metadata by dragging with the media tool — another method is to delete the .mdb file, re-launch Symphony and let the application re-scan, then drag it into a new folder.
    I can’t think of anymore conflicts other than some fundamental mismatch between media types and project settings between Symphony and Resolve Evelyn.
    You are exporting a new AAF from Resolve, correct?… and conforming with the Avid MediaFiles/MXF/# catalog protocol…
    jPo
    “I always pass on free advice — its never of any use to me” Oscar Wilde.
  • Chris Coote
    August 27, 2014 at 1:24 pm
    Yes, new AAF from Resolve – the one Resolve creates when using Avid AAF round trip. And conform using “assist using reel names embedded in source file”. Have tested this and it works.
