Activity Forums Apple Final Cut Pro Legacy Avid AAF in FCP 7.02
  • Avid AAF in FCP 7.02
    Posted by Jon England on December 20, 2010 at 3:56 pm
    We’ve been given this Avid AAF exported project to conform in FCP. We can import in onto the timeline via Automatic Duck.
    The problem comes when we want to ingest the hi-res versions. FCP wants to ingest the complete asset rather than only the sections on the timeline.
    This is a massive project taken from weeks of material.. and as usual, we don’t have the luxury of said weeks to get all this ingested (let alone the disk space!).
    What’s the trick in FCP to force the ingest of clips that are only on the timeline – not the whole asset?
    thanks in advance.
    John Pale replied 15 years, 8 months ago 4 Members · 5 Replies
  • John Pale
    December 20, 2010 at 6:22 pm
    You have to consolidate or decompose on the Avid before creating th AAF or you will still reference the full master clips.
    Must be fixed on the Avid side.
  • Shane Ross
    December 20, 2010 at 7:37 pm
    What he said. Just confirming that THAT is the proper workflow. Consolidate on the Avid side, with handles…to only what is used in the show. THEN export the AAF.
    Shane
  • Jon England
    December 21, 2010 at 12:22 am
    Thanks guys…
    That confirms our fears. What if the original avid
    project assets have been deleted? Do we have no other options?
    Xml or edl export/import from fcp? Apple suggested editing the xml timecodes…
    Which would be an option if we had all decade.
    Thanks again
  • Michael Gissing
    December 21, 2010 at 12:47 am
    I take it you recapturing the media? If you have the edit sequence in FCP, try using Media Manager to create an offline project, deleting unused media with handles. I don’t know how it would work with a project that is already offline, but if the clips have proper timecode and reel numbers it might create a timeline with just the final media as cut (plus grab handles).
    It would be pretty quick to test
  • John Pale
    December 21, 2010 at 4:45 pm
    You can do this on any Avid, with or without the media if you have the bin/sequence .
