Activity Forums Avid Media Composer Avid 8.3.1 media is crashing Avid 7.0.3
  • Avid 8.3.1 media is crashing Avid 7.0.3
    Posted by Brad Kimbrough on April 30, 2015 at 8:10 pm
    Hello!
    I run Avid 8.3.1 on OS X 10.8.5.
    I’m background transcoding a standard def QT (H.264 480 x 360 44.1 Stereo) into a 1080p/29.97 project. Then I’m bringing that bin into a 1080p/23.976 project (still on MC 8.3.1). That all works fine, no problems at all.
    The problem arises when I copy the bin & media to another machine running Avid 7.0.3 on OS X 10.9.4. When I try to open the clip or sequence, it hard-crashes the Avid (segmentation fault).
    It’s worth noting that this workflow is fine going in the other direction (background transcoding on a 7.0.3 machine, then copying bin & media to an 8.3.1 machine). But it doesn’t work when I go 8.3.1 –> 7.0.3.
    Any help is greatly appreciated — thank you!
    Brad
    Brad Kimbrough replied 11 years, 4 months ago 2 Members · 2 Replies
  • Michael Phillips
    April 30, 2015 at 11:02 pm
    It might be worth trying to 7.0.4 which may have more backwards compatibly with 8.x.
    Michael
  • Brad Kimbrough
    May 1, 2015 at 7:25 pm
    Thank you, Michael.
